152XS Compatible Remotes?
The battery compartment cap on my NARCOM 4 remote broke. Ideally, I could just find a replacement cap but I assume that’s almost impossible.
I’m having a little trouble finding a NARCOM 4 replacement. Does anyone know if other Naim remotes are compatible with my 152XS? That would help me expand my search.
Any Naim Narcom (1-5) should work fine, otherwise an i-com, R-com, or Flash.
FWIW, I know what you mean about the Narcom 4 (AKA the Stealth remote). One of the dogs had a go with one of mine (naughty boy Twig!) and the battery compartment cap has never been found…
Adeotec, speak to James Allney at TomTom Audio in St Albans. He will either have in stock, or be able to find for you, just about anything Naim-related.
I have no financial interest - just a (very) satisfied customer.
