I use the ATC remote control but all I use it for is to switch the amps and streamer on/off. Being a ‘one remote for all products’ type of thing there are loads of other buttons which are 100% surplus. I’ve been trying to source a really simple IR remote which has just a couple of buttons that can be programmed. So I can use one button for on/off the streamer and one for the amps on/off.
Anyone know of such a product?
