May I seek your advises, I have 2 powelines and 1 powerline lite, which devices should I use the PL?
SN2, Hicap Dr and ND5XS
I did a A/B test of PL goes into Hicap or ND5XS with PL on SN2, seems putting the PL into ND5XS gives a more details of the music where when the PL is plugged into Hicap, it gives more energy. Will do further testing to use the 2 PL into Hicap and ND5XS and lite on SN2 , what are your advises?
I have anything plugged into Isotek Sigmas, thank you everyone.
I would put the lite on the hicap and the two powerlines on the source and amp.
Why ?
The source and amp will make use of the juice boost, while the pre stage already has the juice boost from the hicap.
The SN power amp section takes a lot more current than the other two items, plus it’s constantly variable with music & volume, therefore the SN must have one of the Powerlines.
The ND5 load is very light & hardly varies, & the same for the HiCap, it’s only powering the SN preamp section.
That means which one has the other Powerline, I would let your ears decide. Then please post what you find.
