Good morning, I would appreciate some advice and a quick sanity check on my set-up just in case I am about to blow up something!
My main system is an analogue only set up with two separate systems on one rack. System 1 - nait 2/ kan
System 2 - 32.5/250/hicap/ iota alpha
The source is an RP8.
To stop having to power down a system and then change over the source between to the two set-ups, I have added an RCA splitter so I can do this with a touch of a button
The other sanity check question is why youād possibly want two systems in one room. The Kabs would be so much better on the end of the 32/250. Why not put the Nait in another room?
Two systems are better than one! In all seriousness, they sound very different and serve different purposes, the 250 plays loud, the Nait is for Low level listening
Thanks for the reply. To be honest Iām not really sure which has the best phono stage.
I would be good to work out a solution, if using the TT could be an issue I could swap this out for a CD player when I want to switch between the two systems. Would be nice to get the TT in a working solution thoughā¦itās really interesting to switch between the 2 systems mid song and hear the differences between ampsā¦
This from AndyR is the best way to do what you want here. I would not want that splitter between the turntable and the phono stage as it must only cause performance loss.
Certainly will, he is a nice chap, I get the feeling when he is tired of selling stuff he will convert the place into a museum, he has a great collection of vintage gearā¦
