good morning everyone.
As always forgive me for my bad English, but I need help.
I have problems with the rear fuse housing of the 250/2.
It has basically come loose so the fuse dances and with every movement of the final it goes out. Has it ever happened to you? and how did you solve it? I thank you in advance. Giuseppe
Can you post a picture?
I would suggest removing the power cable.
Reinsert the fuse in the holder.
Firmly push the fuse door closed.
Did you remove and replace the fuse?
If its the two metal pieces that grip the fuse then course remove the power cable FIRST remove the power cable. Remove the fuse, then take a small set of needle nose pliers and squeeze both metal part so the the fuse is snug. then put the fuse back and so on
ciao Robert sì ho fatto tutto questo, è andato bene per un po’ ma poi è tornato come prima,Tanks
come lamelle intendi quelle che stanno sotto l’ alloggiamento? Grazie
by slats do you mean the ones that are under the housing? Thanks
