I wonder if (1) AV Options will continue to have access to the upgrade kits and (2) whether this applies to them as well. It may well apply if Naim will only provide parts in a kit that includes both full service and DR upgrade items!
As a Naim Authorized service center I suspect they will have to follow suit.
As another user that has had a 202/200 setup in the past, I too went for the 282 first (which worked great with the 200/HiCAP DR/NAPSC combo). I have since moved on to the 250DR. I can say that back then, when I was looking around for upgrade info there were a lot of posters that said the reg 250 was not a good match for the 202 & they preferred the 200. I believe the 250DR might work a bit better with the 202 as I have heard of some running that combo & not having issues. So my advise would be to listen first (especially if you go the pre DR route) if you do swap amps but my main advise would be try a 282 instead (or add a NiCAP DR to your existing setup)
