My question to the group is
I have the chance to upgrade my 200 to a 250DR ,
Or would I be better to add a XPS to my ND5SX .
I would like to here from someone whom as owned both a 200 and250DR if possible
Cheers pete
Hi, the 250 is certainly a more capable amp than the 200 in the right system. However, I would not add one to your system until you gave upgraded both source and preamp. 282/200 is a better match than 202/250.
Adding a PSU to your streamer is one option, but you could also consider upgrading it to an NDX first, or adding an external DAC.
Also, think about whether you want a newer streamer that will give you access to higher quality music sources such as Qobuz HiRes and lossless iRadio.
…also, think about how your system is set up. Your preamp, in particular, will not be happy sitting on top of a power amp, and these issues become more important as you climb the upgrade ladder.
Thanks for your advice Chriss , separating the amps can be easily done
I’ll definitely think about upgrading the Nd5sx as it as become the weapon of choice
If the 250 is a bargain then get it while its available. The 202 won’t make the best of it but you will have it in place ready for when a 282 or even better a 252 turns up. The 250 may just be the best amp that Naim makes in the sound quality per pound spent stakes.
Urm, if I was brutally honest I’d say sort out the racking first and then logic would say 282 although the 202 is a very competent pre in itself but the 282 just opens the music up. However, those Focals look like they could be quite demanding so grabbing the 250DR now could be a smart move.
I would trade in the lot for 272/250dr. Then you would have a better source, similar level pre and better power amp. Racking less items will allow components to be separated which would also improve sound. You can always add a ps if/when funds allow. Alternatively Ndx2/supernait 3?
LOL. Nicely done. I would suggest avoiding placement directly under the turntable, as the very low-level cartridge signal can be sensitive to nearby digital circuitry.
