Can the front panel lights on a 252 be turned off?
Yes, use the display button on the top of the remote. You may need to check that the remote is set to āpreā.
The only thing you canāt switch off is the logo - itās illuminated to show when itās powered on.
Thank you - you mean the remote that comes with the 252?. Canāt do it from the app presumably
Yes the R Com remote
Its not possible with the app as the 252 doesnāt have any wireless function.
Thanks - Iāll give it a go. No point leaving lights on unnecessarily
With the ādispā set to off, the lights will come on for a few seconds when you change something such as volume or input.
All done - easy when you know how!. Thanks
Manual
ā¦ because itās the light that guide us.
