The 552, even second hand, is still too expensive for me. I was waiting to find an excellent opportunity (within 5-7000 euros) as I had happened with the nap 500, but in recent years I have not found anything about these costs. On Saturday I will have 252 at home to try it out with my NAP 500. I’ll listen to it and then make the final decision.
A question: to connect the 252 to 500 I didn’t find any schema. Is it similar to the connection between 252 and 300 (so two cable from super cap to Nap 300 or Nap 500. )? Which cable do I need?
Have never heard of anybody running a SN2 as a pre into a 500 before. Was curious as to how you’ve found the sound thus far? Because obviously that system is a little unbalanced.
It works. Obviously it is a temporary configuration, as I was not able to move from the Supernait2 to a pre+final in one shot.
Sound was not so bad and for sure better than the Supernait2 stand alone.
Hi, I listened to the Nac 252 connected to the Nap 500 and it was great.
So I decided to buy it.
Maybe in the future I will have the option to upgrade to a Nac 552, but for sure in the meantime I will enjoy fantastic sound … much better than that provided by supernait.
Thanks everyone for the support and advice
PPT
