Hmm, a but of a sideways move, particularly if you’re going to continue with the Macbook/Audiavana and not intending to switch to UPnP streaming from a NAS.
Saving to replace the 202 with a 282 and then a HiCap is likely to be a better option.
Just worth noting that the latest version of Audirvana has UPNP capability to enable streaming as well as Tidal, Qobuz and HIGH Res Audio integration (if you are not aware already).
