The story is, I try to dispose my 200DR bought last jun still under warranty at half price without success. Since I have the spare piece and the 2 hicap upfront, just wanna do an experiment may be this Sun.
Agreed with most of you that 282/300 drive my ProAc already very well, not sure the act will add value or … play by👂
Sounds like a fun exercise. Please post the results and lessons learned. I’ve always been curious about doing something like this with my SN3 and ProAc D2R’s.
I’ll have a spare SN2 soon and might try bi-amping with my Nova, as I have all the cables. Do you remove the speaker bridge or is that just when be-wiring?
PB without an active crossover the OP has zero control of the levels of the two amps. So one will play louder than the other. And it will probably sound like Poop…
In days gone by I did actually have a true Active bi-amp system. I had Apogee Mini Grands. Mini Grands were Apogee “Stage speakers” on top of separate bass cabinets that had a pair of I think 8" woofers so a total of 4 woofers. Then it had the active Crossover called a DAX ( Digital Active Crossover) The DAX allowed for the Level adjustments of both amps also crossover point and low pass filter . There were also the Stage Grand which were Apogee Duetta’s with woofers and the Apogee Grands which were huge and $25000.
Anyway I ran my mini grands all single ended using XLO Reference and Symo speakers cable. Symo was a swiss cable that the Apogee folks thought sounded the best on their speakers… Kinda like Naca5 and Naim. I used an Adcom 5800 to drive the woofers and a Classe’ CA200 to drive the Panels… something like 500wpc. It would have never worked with out the DAX …
I had long 7mt interconnect from Preamp running under the floor up to the DAX and speakers and amps at the other end of the room. Then 2 more pair of XLO reference to the two power amps, then two pair of Symo from the amps to the speakers.
It was a fun system but looked a bit over the top. I have pictures somewhere if I can find them I’ll post them. But lots of pictures if you feel like Googling.
