3.12 Firmware
The interesting thing would be to have a new firmware on your DCS that sounds less involving than the precedent, and that you can’t go back.
If not, you will probably say that DCS knows how to do the things right, at the contrary of Naim lol.
:zany_face:
You tease frenchrooster.
But i don’t think naim dacs have the capability to store many different maps, filters, etc. But they might be able to? Others use the burr brown chips, not sure if they offer different maps, etc, that the chip can run, never looked.
Can’t say. Try to see if CH Precision can offer different filters and maps, as the use the same dac chips as Nd555 or Nds. Their dacs are very expensive. ( C 1.2, around 80k with additional clock and ps).
So now I have brought back in Audioquest Vodka in the chain.
Fibre broadband switch > BJC > Router > AQ Vodka > EE8 switch > Farad 3 > AQ Diamond > Phoenixnet > Sigma > ND555 > 555PSDR >555PSDR > 552DR > 500DR
The new 3.12 can now handle Vodka in the chain. Gives the sound more velocity. See how it goes in the chain!
Dan, I was thinking about you yesterday when I started to re-read this thread. Your initial reaction to 3.12 was summarised by the quote above. Do you still agree with that early assessment?
Us NC owners are still waiting for the new FW. The development wheels turn agonisingly slow at Naim as we all know. Anyway, if the end result for me is as you put it above, that sounds like a worthwhile upgrade to look forward to.
I enjoy my system very much these days, it sounds really impressive, the best it’s ever sounded, especially after the Sigma v2 was added - but perhaps it is just lacking a tiny bit of bounciness and fun… possibly just a little bit too “hi-fi”… :thinking:
I might be imagining this stuff due to overthinking, but I do have a belief that Naim has now had a LOT of time to work out how to properly mitigate the issue caused by the stream unlimited firmware (which led to excessive processing power). So I can’t help thinking that the current NC FW is compromised. Not badly by any stretch, but just not quite as good as it could be and not as good as the FW that preceded the whole FW debacle (the NC equivalent of 3.8).
I’ll be excited but also very nervous about updating. The ‘debacle’ has cost me SO much time, money and frustration to finally get to the point of SQ happiness. If I’m honest I still harbour a bit of resentment at Naim, it literally makes my body temperature feel elevated when I think back to those days. I know I know, no sense in looking backwards. I’m like a Sicilian, I can’t forget :laughing:
My system has always been drowning in the Vodka.
Mine is:
Optical BT Router →Bog-standard CAT5 (10m)→ Cisco 2960-C switch
→AQ Vodka (1m)→ ER Switch →Kabel Direkt CAT 6 (1.5m)→ Melco Server
→ AQ Vodka (1.5m) → ND555
The length of cable between boxes has an effect I find. 1.5m seems a sweet-spot and shorter can be more detailed but aggressive and longer more natural, but gradually losing detail.
I found mixing types essential, as all the same was either bland or oppressive, so experimenting is worthwhile.
Of course we know it makes no difference -etc..but this is what I found.
The present 3.12 FW is not IMO ‘perfect’ if one is looking for the best parts of every FW version I have ever installed, but it has a mix of its own strengths that goes for a very open (low noise), fast and detailed presentation with excellent dynamic handling of both large-scale and micro-detail in music.
DB.
Can you say a little bit more about what this optical BT router is?
I have a BT router that is just over three years old, I think it was called the BT Smart Hub 2.
EE full fibre optic cable comes in the wall and is then converted to electrical ethernet cable (BJC) to this router.
It is the Hub 2 - connected to the outside Optical network.
Okay, thanks. That’s the same as mine by the sound of things.
I have to agree with you. There are elements of 3.11 I liked and elements from 3.12 equally satisfying. Almost a shame you can’t have the best bits from each!
Hi Stavrose,
I am glad to say that the 3.12 firmware continues to deliver in spades! And with the audioquest vodka back in the mix it is sounding superb.
Just done the new mains as well so that should lift things again.
Best wishes
BD
:flexed_biceps:
Glad to hear that @Dan_M
How would you describe the Vodka effect?
Like I said previously, more velocity. It’s faster, more punchy. Previously I had BJC in this part of the chain. Now trying Vodka.
Excellent analysis DB as usual. I’d put it this way. 3.12 is a better version of the 3.11 sound signature . 3.8 v 3.12 is a “six of one half a dozen of the other”. I just happen to prefer the “six” that comes with 3.8…
I find 3.12 a development onward from 3.11 and overall an improvement on the latter. I never really got-on with 3.11, other than it was vastly better than the previous 3.10.
3.8 is a different signature with a lot of aspects I miss it terms of a more open top-end; it did not bring everything together with the timing precision of 3.12, but there was a grace in just allowing the music to be there.
But 3.12 does do things that 3.8 did not.
DB.
Spot on.
I try not to analyse the sound too much but rather go by how emotionally connected I feel listening (I suppose that is why vinyl is my preferred source) . Based on that MO as impressive as 3.12 is the cliche less hifi more music applies to 3.8. IMO. But Naim have done very well in extracting the best from the latest module. Future full software autonomy would be ideal.
Just to update: I haven’t had a crash for a long time. The factory reset seems to have fixed the issue after all. I did not get any reply from Naim regarding my support request b.t.w.
Good for you, that must be a relief.
Naim’s customer engagement is more silent than their transformers unfortunately.
Thanks DB
Having Server Mode ON is essential IMO. It brings much better definition, focus, weight, and a more ‘correct’ overall presentation. With it OFF, you get more bloom, but it feels artificial.
