Hi @dave-marshall,
This is currently default behaviour whereby, because we don’t store the last sort-order used (though it’s on the list!), all Favourites default to the Homescreen Favourites order which, apart from Presets**, are in date-added-descending order. The principal behind the Homescreen sort-order is that, having added a bunch of new Favourites (including Artists), a user may want to have quick access to their latest ‘acquisitions’.
** Presets can be custom-ordered via drag-and-drop
Hi Tom - have discussed this issue with Russell H at your end before: if I filter by Tidal or Qobuz then the correct order-by-date added is displayed but if I take off the source filter (ie. Local (presume this means UnitiCore) plus Tidal plus Qobuz) then order-by-date added doesn’t correctly display by date added. Which is a pain for just the reason you state: it’s nice to have the most recently added items at the top of the list. I have ticket currently acknowledged (124564) for a bunch of issues but am awaiting the start of the support process.
