I’ve just bought two ex-demo NPX300 power supplies for my 300 series system and need to rearrange my rack. I want to check what the consensus is on stacking order.
This is what I’m planning (from top to bottom);
Personally, I would put the two PSUs at the very bottom and the amps above, assuming you have a single stack rack. I think I would also swap the order of the 332 and 333.
Personally I put power amps the furthest away from preamps and sources because they have fluctuating current draws and therefore the impact of the transformer is also fluctuating. Whereas power supplies like the NPX300 are stable constant draws.
I am having my 222 replaced with a 332 and 333, also getting an extra 300 today. Once my dealer has installed this I will let people know what they do. The only thing I am certain of is that the LP12 will be on the top shelf.
I agree, two racks would be ideal. However, my rack fits snugly in the alcove to the left of the chimney breast. It’s a small room and there isn’t really any other practical place it can go.
