OK so the upgrade bug never subsides stops does it? Very happy with how things sound right now but always wondering if there’s more. Anyone following my posts will know I’ve done a ridiculous amount of upgrades this last 12 months, and the most recent 552 was the best of all. So currently have:
NDS+555DR
552DR
300
Kudos 606
KS-1 speaker cable
Out of the box Naim cables
Dedicated mains supply is coming soon.
What would a 300DR add?
PS a non-DR NAP500 P/L is in budget but it won’t fit in my rack so it’s a no go. We all have to draw a line somewhere!
PPS it might be possible to incorporate one into my rack. How would a NAP500 compare to a 300DR?
I made the move from 300 to 300DR and can say it’s a very good upgrade. More punch, grip and blacker blacks.
I use a 252 and love the combination.
I’ve heard 300DR and also a 500 on a 552 and preferred the 300DR. Not as impressive on first listen as the 500 is a real attention grabber, but I found the longer I listened the more I liked what the 300DR did in comparison.
Nice. 500 would be a really good upgrade. I’ve seen 2002 units go for £5 to £6k. Service from class A should be less than £1k. I reckon that would be better than 300DR!
I have a similar system to you but with a CD555/555PSDR fronting it. I currently have a 300DR and it is a very fine musical amp and great value. I too have upgraded my system in the past 2 years and obtained CD555/555, 552DR,300DR and KS1 on my Titan606. My new(to me) 500DR arrives this week and it was inevitible that that was where I would end up.
There is no doubt you will be delighted with the 300DR but if your ultimate goal is the 500 series then go for it now and enjoy it in your fine system.
