I typically can’t stand ported speakers. It’s one of the very few ported designs that doesn’t sacrifice speed and rhythm. It’s based off F1 diffuser technology.
Placement is not as critical and they work well in smaller rooms and don’t need a ton of space behind them.
Hi @matthewk would you mind elaborating on this a bit? What issues did you have with the 333/332?
The Classic equivalents such as NDX/282 etc. were certainly pretty clunky compared to the all-in-one models, and Naim have obviously tried to address this, so I’m just trying to understand where the shortcomings are.
I want to be clear. There are no issues. But it’s just clunky. The two remotes are different. You have to pair the 333/332 and then it seems like the 333 controls most of the operation. Digital 3 on the 333 corresponds to the “stream” button on the 332, Preamp 2 on the 333 is the “Phono” DIN input. I’d rather use the remote from the 332 since I can directly select sources button, but there doesn’t seem to be a way for that to communicate back to the 333 that I want Digital 4 when I push the stream button. Worse is that I can’t seem to disable to less than 5 input options on the 333. I’d love to get rid of Spotify, Naim Radio, Tidal and everything and just leave the Apple TV (digital 3). I only use that and Roon.
Again, once you get used to it isn’t not a problem, but it could have used a bit of human factor engineering on the user interface/app/physical buttons. It’s clear the 333 is software driven and the 332 is more of an embedded system. It’s certainly not as clunky as I found the NDX/282, but it’s similar in may ways. Just not intuitive.
All of this is just me being a picky engineer. I am guessing some people wound’t be annoyed. The sound is well worth the curious integration and usage between the two.
You are not being picky, it really is something to consider in products at this price. Although cost is the main reason I haven’t (yet) gone the route you have also the ease of use with 222 is a big factor. I actually felt the 272 was even better and easier to use in this regard.
There really is no excuse for having different remotes. In fact whilst you mention the NDX/282 was clunky, l use in another system NDX/Nait XS with system automation I only need the NDX remote and this selects inputs on Nait as does using the Naim app.
I hope that perhaps some software updates could perhaps improve things a bit.
Thanks for the info as I found what you highlighted very important to potential buyers.
Thanks. I don’t think there’s anything there I couldn’t live with. I would only be using one input on the preamp.
I never use Naim remotes, to me they are horrible and they stay in the box. The 1st gen streamer remotes were so much better. I just use the app.
Preamp input selection should be accessible in the app once system automation is set up. I agree that it would be nice to disable all unused inputs, but this has never been an option with previous models. At least you can change the order in which they are displayed, so that the ones you use are at the top of the list.
No, sorry I meant the streamer inputs. Some can’t be disabled (such as USB, Airplay) so they always clutter up the front panel display and the app.
Some of us asked Naim is they could change this, and the answer was no, but instead they implemented the option to reorder the inputs on the app, so that at least you can put unused ones at the bottom of the list.
