I have an opportunity to try a Supercap DR on my 362 Active Crossover. What burndy should I use? I am powering it now with 3rd party PS using snaics so no burndy.
Thanks!
mike
Thanks!
mike
Naim Snaxo/Superline Burndy
You need the 17 pin burndey ( Snaxo Superline burndey) collar Band towards the SC😉
Thanks gentlemen. I will try and locate a used burndy and compare.
