good to know. Personally i will stay with the 4.6, and 4.7 will be the nd555 …
NO !!! … 4.6 & 4.7 are for NDS NDX etc., ND555 has a completely different firmware program
it was humor, Mike. The next update for me will be the nd555.
Maybe its a better joke in French
i am the only one to laugh, it happens. Should i see a psychiatrist ?
I am trying to have british humor…
Ah that might be a bit tricky. It takes 3 or 4 generations to get that bred into a person.
I understood you instantly FR
Perhaps you are not british ?
Born and bred in God’s own country Yorkshire, England
i am pleased to have been understood. Thanks
French humour is obviously too subtle for some of us Brits, I had to read it twice
i am honored
Updated my 272. First time I have ever done a Naim firmware upgrade. It all went smoothly and took less than 15 minutes.
FR, you just did self-deprecation. That is very British, you’re learning fast, mon ami!
Hourra ! i got it a bit, i am on the right way! You are my teacher in this department.
Am I correct in thinking that 4.7 provides the same Tidal fixes etc as 4.6 but without the sonic changes that 4.6 brought thus allowing the 4.4 presentation to be retained with the Tidal changes, or has there been further tweaks to the functionality.
I also find the update process very simple and switched between 4.4 and 4.6 several times before settling back on 4.4.
ah, didn’t realise this thread exists! As I asked elsewhere, I’m keen to hear from folks who didn’t like the 4.6 upgrade (like me) but find 4.7 better? Thanks…
enjoy/ken
Hello, frenchrooster. Are you using ndx2 or NDS now?
Not if you want to listen to Tidal…
Hi Ken, there really hasn’t been any opinion expressed on SQ change. I personally don’t hear any difference with my NDX, but I remember NDX & NDS owners did have split opinions in the past.
My advise is if you have kept a copy of whatever firmware you currently have, give it a try, you can at least go back. I also note that Naim Support has firmware 4.4, 4.6 & 4.7 available
