4 box advice
Currently NDX2, XPS DR, SN2 and HiCap DR. Would a move to NAC332 and 250DR be a worthy upgrade whilst retaining just 4 boxes?
Just go 3 boxes
333/332/250 NC
It’s what I’ve done and it’s fantastic
Still got NDX2/XPS2 in another location but the 333 is in another league
4 boxes, all NC is what I have in Sydney - as above but with the PS on the streamer.
Customer of Audio Genesis Blythe ?
Yes indeed :slight_smile:
:+1: Harry is the Guru
I’ve no dog in this fight but thinking that if you’re changing amp then NAC 332, NC 250 makes more sense…
The lead supplied with the 250DR won’t fit the 332, so you would need to have one made up. There’s no reason why it shouldn’t work well though.
The suggestions that you should just get more New Classic stuff are all very well, but that’ll cost you a whole lot more. You already have a good source and the 332 helps to keep down the box count, so I think your proposed system is a great idea as a way to stick to 4 boxes.
