5 Lego bricks only 2 shelves
I’m a big fan of Isoblue, which I’ve been using for quite a few years and if it fits into your existing shelves it could be an easy way to increase their capacity.
If you do consider using the 3rd shelf where the headphones are, bear in mind the length of the standard interconnects can limit what goes where.
Also if you’re not in any hurry, wait and see if a streamer/preamp would fit your plans/budget better.
Your patience may be rewarded.
