With the 808s you could just get yourself another 500 and run each 808 from both channels of a 500 - one channel for the bass section and one for the mid bass / treble section using a Y input cable.
If your at this level though, active is probably the way to go
So I am back to a single P.S.
What did the 2nd PS bring? More slam, a more solid bass, more detail in the bass, slightly more open sound I think. In my room it didnāt work - I do not need more bass. And maybe it was a psychological thing, but I couldnāt feel good about having half of each box sitting idle - in todays world that just doesnāt feel like a good use of resources. So I went back to 1, and you know what, the system sounds phenomenal, just as a 500 series should
I have instead invested in another cable, and will probably go with the music power block and Sarum power cables which take the system to a new level, although for admittedly for a little more outlay
Agree this twin supply game and then just use half off it makes no sense to me whatever, use more power, take up more room, cost a lot as well, for a very small inpovement if any. Much better investing the money on a better amp, source etc, or even better cables maybe as that will certainly bring a much bigger inpovement to the system.
I did have a 2nd 500 squatting in my music room but I must confess I wasnāt sure how to use it with the 808sā¦ so it sat idle.
TBH the system knocks out music with so much gusto, Iām not sure the 808s need more than the 1 x 500 (or maybe just sometimes better to live in ignorance? )
The Music cables by the way really bring a lot of life to the sound - but I only really realised that gain in my system with the full loom. The system with and without is a very different beast.
Actually, I say full loom but I am still missing the Music din > xlr cables for the 500, which should be here in the next week. Then I am properly full loom (albeit using Sarum for power cables) - I am looking fwd to seeing what the last link brings to the party, although I have learnt to just let the system run for 100 hrs with new cables before making any conclusions. Not easy for me as I am not super patient!
You simply use one 500 per channel. using the left channel of one 500 and the right channel of the second. You would need a Y connector which Naim would supply.
I did this with my ARTās and was very happy with it.
