Hi can anyone help…led’s on volume, balance and sources will not switch off with remote …
tried powering down then back up again…no good. Volume on remote works…and inputs … can anyone advise…
Make sure you select pre button first then disp . At least that is what i have to do on my 282.
Thanks worked a treat …cheers
When a CD5i was my only Naim, I even took the remote to the dealer once because of this. Thought it was broken as id had stopped doing anything for the CD player
Indeed I have to admit this has caught me out too (and sadly more than once!).
.sjb
Me, too! Elegant solution, when I finally grasped it. Nick
Yes worked on my Nait 5i the same press the pre button first.
