Hi disp has stopped working on the remote…can anyone help…
I think you need to be a little clearer…
Do all the other functions work?
Yes…and when I use say volume all the lights light…correctly…can I reset the remote???
Have you pressed the PRE softkey beforehand to tell the remote you want to control the functions of the pre-amp (beyond just volume).
Sorry for the numpty reply is this the pre on the Narcom…or are we talking about 552…buttons (I think there is a pre I am away from house at present)
Found it…sorted thankyou!!!
