Masse
1
Hi all
I recently bought a used 555 pa dr to my nac272 with enormous improvement.
The burndy cable that came with it is a 11 pin SXPS. And it works in my system.
Now someone told me it’s the wrong burndy…
Does anyone know which burndy I should use?
I don’t wanna power up my system until I get this cleared.
If it says S-XPS on the collar then it’s the correct cable. This is what mine looks like.
Mine also has a collar that says SXPS, as above.
Masse
4
Same here. I plug in again
Thx guys!
system
Closed
5
