Is it best to plug 555dr into wall socket or power block.?
Wall socket preferably on dedicated radial spur.
Mine are plugged into a musicworks power block….the power amp plugs into the other socket.
Opinions are ubiquitous, consensus improbable
I have to get a good power block i do have russ andrews Xblock but this filters an unfiltered might be better.
I feel all depends of the quality of the powerblock. All members with a good quality powerblock as Music works or Anzus have their 555 ps connected to it.
But for power amps, some prefer directly to the wall, other not.
