729 boards
i have a spare set of 729 boards, can i use these instead of the 324 boards i use on the tape outputs?
AFAIK, the NA329/729 time aligned boards are only for replacing the input NA324 boards.
Hi Richard, thanks for the reply. I thought that might be the case .
