It was done in one go, the result a TOTAL system SQ transformation, barely 48hrs in very well known tracks are presented in a different soundstage arrangement, positioning, bass depth (ouch) layering a wide stage and an effortless presentation that flows, bags more detail (vocals, subtle bass shifts, layering, lead vocal clearer, backing vocals now clear not muffled, then quite subtle repeated vocals in the background.
So if 48hrs is a new transformed level of SQ, 200hrs will be something more spectacular, system is running 24/7.
I should hit 200 hrs next Saturday, but from cold the power cables, fuses, usb, ethernet and speaker cable are on another level not a simple step up in SQ. I think the some what recessed midrange and slight HF roll off will disappear.
Though at the moment I think it has shifted from the Naim character in terms of PRaT.
Bar the mains cable to the Cisco switch I have now achieved a full loom and extras of Synergistic Research Foundation Series loom.
To my lowly Nova, Zenith, Focal setup, I have added SR cabling to the Zenith, USB and Ethernet and also speaker cable. In addition the new SR Purple fuse to the mains block, Nova and Zenith.
This adds to MiG 2.0 supports under the Nova (SR power cable) and Zenith and Carbon XFT for the Focals.
Only future upgrades are the SR Network switch, but the power cable and ethernet, put it on par with a Nova RRP.
