Hello, i have a problem with connecting headline headphone amplifier to my supernait 1. Does anybody know what might be the issue?
I assume it’s the standard Headline with a captive DIN5 interconnect. Which input are you connecting to? If the Tape in/out then by default this is set to a digital input, so you will need to re-assign. The user manual explains all here.
Once properly re-assigned you then select which source you want to listen to via headphones on the lower REC input button bank, and the Tape (Headline) button on the top LISTEN button bank.
Thank you very much for help, i I didn’t expect it to be so complicated.
