Hello,
I just saw a “strange” bug using the native Qobuz integration within the Naim app.
If you choose in the Qobuz menu the last item (Qobuz shop buyed items), the Naim App replace the Qobuz logo with the Tidal logo and the menu became the Tidal menu (and work as this)… even if your Tidal input is desactivated.
Does some others can try this ? I am using the Naim App on Apple iPad & iPhone.
How to send a bug report to Naim ?
