Hi all,
I recently got some used K20, to taste the naim house sound before getting A5. I enjoyed the K20 more than either my existing Odyssey 2 or the loan Epic X on my XS3+ND5-SX2
I initially had the K20 on old no-name screw fixing banana plugs and decided yesterday to terminate them properly at the amp end with the naim plugs (speaker end already had Deltrons fitted).
When I plugged them back in I felt I could hear more but, the bass lift was insane, boomy and very hard to deal with. It sounded like room colouration but I had not moved the speakers at all (Spendor A7).
Does K20 / NAC-A4 have a bass heavy signature? Just to make sure Iām clear here, this happened after I properly terminated the speaker cables.
Though one things people always forget when they swap in a new speaker cable and say the change was immediate and dramatic is that it is not the only thing that changed. In nearly all cases the amp was powered down while this was done and the sound of a power cycled Naim amp is nearly always bigger than the difference in any cable. As such I would suggest:
Give it a few hours. Does it calm down?
Did you use the right amount of solder at the proper temp? Are the connections tidy and shiny or cloudy and a bit dry or globbed with too much solder?
You might be hearing how the amp and speakers really sounds together in the room that a poor connection masked (especially if the screw connection was just biting a couple strands).
Hi there,
Thanks for reply. Yes gave it plenty of time. Itās on day 2 now. Connections are shiny. Wasnāt aware of a specific amount of solder I should use though.
I agree that it could be the natural sound off the room but the The Epic X I had was properly terminated and I didnt get this messy, resonant sound. Same with the prior XT6F so I dont know thats the whole answer.
Ohhh I thought you had also heard the K20 prior to termination without the problem but you mean you got it second hand and immediately terminated it?
So really you are comparing the Chord to the Linn. Do you still have the Chord to put back. A standard sanity check in troubleshooting is to revert the change and confirm the bahaviour also reverts.
Itās not impossible my. When I first put them in I thought the bass was more noticeable than either of the chord cables, so I would be surprised. I checked phase earlier today and they are certainly in phase at moment. When Iām up next I will just swap the phase on one just to see if it sounds more like it did before i soldered them. Thanks
I have K20 and K400(split to single wire).
The K20 dig deeper in the bass, but has a bit leaner mids, compared to K400.
The K400 on the other hand has a meatier upper bass and mids.
Through my SN3.
I prefer K400.
I managed to upgrade to a point where the speakers started shaking the floor. Second side of Led Zep Three, Gallows Pole, particularly excited it. Speakers at the time were Thiels with long throw 6ā drivers, the floor was an Axminster over boards screwed to batons just laid on rough concrete with a membrane between. I think it was adding the supercap that did it. I changed the speakers but maybe isolators would have worked.
If you had screw terminals before and now soldered I suspect the connection is better not worse, a poor connection can lose bass. I suspect you were losing bass before ? I dont think the A7 is a bass heavy speaker, I guess bass is relative. Iāve never heard a 180mm driver deliver very much bass !
