I want to go on my UnitiServe over the IP adress with a software on the iPad (File Explorer), like the access with the windows explorer to see the files in the folders music and downloads.
When I set up the IP adress in the file explorer and try to go on the UnitiServe the software asks for the login and password. I leave both empty, but it does not work. The access is denied.
The UnitiServe works like a NAS and so I thought that there is an access to the folders and files of the UnitiServe like the access to folders and files on a NAS.
You can access the music and download folders on a Unitiserve from a Windows PC as long as SMB1 is enabled and you can actually control the US with a Windows DTC or with n-serve for Mac.
I don’t know why you can’t see the US folders from an iPad, but equally I have never heard of anyone successfully doing that. It’s probably typical Apple network myopia - for instance I don’t think Apple supports SMB? But maybe another forum member has more understanding?
