Anybody able to access twonky settings on melco N1-a via W11? I’m just getting the login screen nobody/nobody doesn’t work, yet those are the credentials for a mapped drive and the backup which both work fine…
puzzled
I found the accessing my UnitiCore from a W11 laptop suddenly stopped working. That was using WiFi to connect the laptop to the network. But when I tried it with Ethernet cable it worked fine again. From what someone said in another thread, it seems like this is caused by a recent security upgrade in the latest W11 patch (ie think is was 24/H2)
this is all ethernet - tried a factory reset on N1, picked up same ip on restart and still can’t get in. was intending to enable the Photos library as its not enabled by default.
