I have a MuSo2 and would like to buy a used Cube1 for the kitchen and use it in a multiroom setting together. Hence stream same music to both speakers in sync. Would this work?
Yes, all Naim streamers can be used together in a multiroom group.
I have an Atom and a QB1 and Mulitiroom works fine between them. It even means I can listen to Qobuz on the QB1 even though it is not natively supported by the QB1.
Roger
Thanks for the prompt response Chris
Thanks for the prompt response!
You should, in theory, get better sound quality by using the Mk2 Muso as multiroom ‘master’ and the Mk1 as client, although it will work in either direction.
