Adding a streamer
Hi all,i was wondering if anyone here might be running the same or similar set up ,supernait3,cd5si,with kef r7 metas,trying to add a rose rs150b?
Use the left and right unbalanced phono socket outputs, set to fixed volume output.
Connect to phono sockets on the back of the supernait eg stream in.
Appreciate your reply ,thats the way ive got it ,but havent set to fixed volume ,thankyou
Yes you’ll need fixed volume, as you will be using the preamp stage in the supernait. The rose can be used with variable output direct into a power amplifier as it also works as a preamp, but here you need fixed line level output.
Thankyou
