Couple of bits of rubber roofing are flapping after the attentions of Eunice. One piece has come unstuck from a “PVC” panel, the other from a wood panel. Neither are overly serious at the moment, and I’d like keep it that way.
What’s the best adhesive to use. Only need a smallish tin, and preferably obtainable from B&Q / Screwfix / Toolstation…
Hi
Clean off and use contact adhesive. Also, all exposed edges should have a mechanical fixture (trims etc.). The sheeting shouldn’t rely on glue to hold it down along the edges.
