For the past couple of years I’ve been using a ProJect Bluetooth Box E to enable playback of a portable Sony device via Apt X and also Amazon music through my phone to my bedroom system.
Unfortunately the ProJect has died so I’m looking at a cheap entry level streamer that will also allow the Apt X connection and playback of Amazon Music either directly or via Bluetooth from my phone.
I’m thinking of a Bluesound Node as the upper limit of what I’d like to spend. I also want something that’s pretty much plug and play.
Any advice before I phone my dealer next week would be gratefully received.
Bluesound Node is hard to beat for affordable streaming and even beyond when used with a good external dac. The new Node (130) is especially nice. App is great and very stable. Interfaces for Apple, Windows, Android whatever you need. I have an NDX 2 on my primary system but also have 3 Nodes being used in my house wired and wifi.
Thanks for replies so far.
When I first found the Project had died this morning my first thought was to get another. But as it’s already failed once before (power supply) I’ve decided that at just under 2 years old it’s not reliable enough and a false economy. For that reason I want a good, solid, reliable unit for around the £500 mark.
I basically need to be able to do what the Project Box did, so Bluetooth Apt X, plus if it were to stream Amazon Music directly that would be great.
I only use the Amazon Music to audition potential vinyl purchases.
On the popular auction site there is a Powernode 2I being shown at 360 pounds with a day or so to go. Just add speakers and its a bedroom system all in one.
