Good morning, hoping to get some advice by people here.
I currently have Chord EpicX speaker cables between my Nait1 and my Spendor Classic 4/5 speakers. There’s an offer for a pair of NAC A5 cables (4.5 metres) for 265 euro (VG condition) with QED Airloc banana plugs.
I am curious if the NAC A5 would be the preferable option for my set up. So I figured the best place to ask is if someone else here has experience with both cables…
I would follow @simon advice. Although i use Epic X myself, if i had a Nait 1 i would absolutely be using NACA5. It was deigned to have the correct electrical characteristics to work with the Nait 1.
I’ve used both cables albeit in different systems, so not entirely sure it will help.
I used NAC A5 with a Nait 2 and it was clearly better than other options available at the time including some early Chord offerings. This was the late 80s to early 90s though. I tried the Chord cables at the time due to a house move when I need to route the cables quite tightly. It worked but they were never really as good as the A5.
I used Epic X with a 282/250, a 252/250 and 552/300 systems. In those systems I preferred it to A5 but it was subsequently replaced by Super Lumina. I had preferred the Epic X to A5 in those cases but the difference wasn’t huge. Cable routing with Epic X was no easier than A5 as it is also a fairly stiff cable. It was more detailed than A5 and a little smoother in presentation as I recall. It certainly wasn’t a night and day decision though and I would happily have lived with either.
Going back to the Nait situation, I’d probably opt for NAC A5 as it is a combination that just works. If you can get a used pair which have been properly terminated, at a reasonable cost, it’s worth a try. That way you can do an extended test over several weeks. If they are not for you, selling on should be pretty painless. My gut feeling is that, with the Nait, you will keep them. Hope that is of some assistance.
If you do go the A5 route then at a minimum, I would get the NAIT 1 ends re-terminated with Naim SA8 plugs. The speakers sockets are PCB mounted and individual 4mm plugs along with the stiff A5 cable can put excessive strain on these sockets if you are not careful. The SA8 plugs help reduce this risk.
Hi Amarok, congrats and look forward to your comments.
Think like Naca5 as part of vintage Naim amps’ speaker output would result in a much clearer answer. It simply enables a Nait 1 to work and sound as intended.
Yes, that’s why I decided to purchase these. But also with the knowledge that my sister chose the EpicX several years ago for a reason whilst comparing with other cables.
I got the set up from her as a Christmas gift as she and her fiance decided to get rid of all the cables and boxes and go wireless with Devialet Phantoms.
I will post my personal findings and opinions asap…
I have two sets of spendor speakers that I run with full Naim systems.
I have historically used chord shawline and epic cables. Very good, and detailed, but on extended listening I prefer NACA5. They are excellent.
I recently purchased some Tellurium cables. Blue 11, and Black 11. These have really synergy with spendor speakers. Similar to NACA 5 but more organic. Certainly worth a try.
Well, the cables were delivered couple of days prior to the weekend. It took some patience to dress the cables in a proper way, but I managed. I have been able to do some listening over the last days.
Music sounds more warm and there is (or at least seems to be) more volume as well. Which is probably also an indication that the Nait1 indeed is working more like intended by Naim.
Bass and lower mids are far more prominent.
Somewhat less detail, which is a little bit of a pity in my opinion with some less loud music.
There is a more coherent presentation of the music, which (I ofcourse only notice now) the Chord EpicX doesn’t achieve. The music and instruments feel more like one piece, more like belonging together.
There was a suggestion from a friend of mine beforehand that the PRaT could improve as well, but I can’t say that’s really the case.
Overall I really enjoy the cables so far and I think the EpicX will have to wait their chance in another set up.
I’ve owned both Epic X and NACA5, though not in the same system. The Chord cable is excellent, but it’s not doing the same things as NACA5. It’s going in a different direction. NACA5 is the best way to go to maximise the musical potential of the Nait 1 IMO. As you’ve noticed, there is more musical coherence. Everything just makes more musical sense. There may be less detail compared to Epic X, but what use is that extra detail if it’s not properly musically integrated with the performance as a whole? It just becomes a distraction. NACA5 is all about the music.
