You can ignore 95% of this thread thenš¤£
Equally when you look at what some smartphones can now achieveā¦
Ideally we would rather not pay more than Ā£1K.
As @Ryder35 says above. Ignore almost all of this thread.
We were spending money that you didnāt haveā¦
(you could easily spend over Ā£1000 just on a lens, for a DSLR or Mirrorless)
Oh hang onā¦ Isnāt that normal on hereā¦?
We might have Ā£1.5K but you can see the ballpark we are in.
But would consider S/H.
Forgive my ignorance but is a āFull Frameā vs a āCrop sensorā the same as comparing a 1 inch sensor vs a half inch one?
Full frame means close to 35mm format - so a 24 by 36mm sensor.
Crop means close to APS-C format - so a 16 by 24mm sensor (Nikon size).
In terms of Focal length, if FF is 1, then Crop is times 1.5. This helps at longer focal lengths, but works against wide angles.
For the Crop sensor, the lens image circle can be smaller, so lenses can be smaller & lighter - relative to full frame.
Should get you a DSLR plus one long-ish lens, maybeā¦ Pre-loved.
Butā¦ the weight & bulk might not be to your likingā¦
To be super clear on @Collywobbles 's behalf, and as stated earlier, a 300mm lens on full frame becomes 450mm on a crop sensor camera. (ie. more telephoto.)
Possibly less relevantly, a 16mm wide angle becomes a 24mm wide angle. (ie. less of a wide angle.)
For reference, a 50mm lens on a full frame camera approximates to the field of view of the human eye. A 50mm lens is traditionally known as a standard lens.
Oh Dear.
I fear you could be in serious trouble now.
A 50mm lens on a full frame camera approximates to the field of view of the human eye
If we assume a Crop sensor as being times 1.5 (relative to FF), then a 35mm lens becomes roughly a 50mm equivalent.
1.6x if Canon?
For ease of use, weight and spec, the Sony RX10 would be hard to beat. Itās currently in its 4th iteration which has been on the market for several years (since 2017?), so it is available relatively cheaply at present. While you would undoubtedly achieve potentially better quality images with a DSLR, high quality long lens, tripod, etc that combination is inevitably much more expensive, heavier and more complex in use.
But therein lies the problem? So the question to the OP should be āhow far do you wish to go/ how much do you wish to spend?ā.
Bit like hifi really.
The OP has said he wants to spend about Ā£1000, possibly a bit more. He also favours something lightweight. So to me that suggests anything but a DSLR. I do speak from experience on this as I have had a few DSLRs, most recently a Nikon D850 with an array of expensive lenses. However I find I am using them less nowadays and would prefer something much lighter and simpler to use. I am looking at mirrorless cameras now and trying to identify what best meets my needs.
1.6x if Canon?
Possiblyā¦ I only speak Nikon, sorryā¦
I love Fuji. But not more moving things. Like speedy wildlife. For fast moving subjects theyāre not as strong as others. Xtrans is still tricky for Lightroom too imo.
S/H
Canon Eos 5D mark iii, then a Sigma 100/150-500/600 jobby of some sort.
Though an R6 would be much better.
I wouldnāt be concentrating too much on selecting a lens.
With the type of photography youāre going to be doing, you should be looking for a body that is able to track moving birds and animals. There is no point buying an expensive lens and putting it on a body that canāt track/focus moving animals.
Although youāll probably need a fast focusing lens, similar to Canon USM lenses. The performance of a lower quality lens can be enhanced by using software such as DXO.
15 years ago I bought a Canon 40D to photograph cyclists, simply because at the time Canonās tracking and focus capabilities where top notch.
Push the boat out a little, and look at the new Canon R50 (Ā£589 from Clifton Cameras) and add the RF 100-400 lens (Ā£618 from Amazon).
A lightweight combo, 375g for the camera and 635g for then lens, and the R50 has a form of subject tracking autofocus.
