I am not sure @Collywobbles is creating a TV production company….
Sure the Sony corporation make many things including hifi
We have been here already unfortunately, I recommended hand holdable 800mm f/6.3 for birding…
However the OP has a very limited budget… so options are perhaps adapters for an iPhone or similar or a compact camera with a built in powerful stabilised zoom… such as a Nikon Coolpix, Canon Ixus or Sony Cybershot.
These can work ok if light is good, and the subject is not moving much and fit within budget.
Thanks for all the replies. I have learnt a lot in the last 48hrs. Many posts have got me digging and reading reviews etc.
It is clear that you have to find the right balance between performance, practicality/portability and cost. Plus it has to come close to expectation of performance and the results you want. We will go and have a look at a few things next week to see if our expectations and budget are even close to each other. We will certainly have a look at the Sony RX10.
Cheers.
You could pick up a 2nd hand one from Wex or similar for under a grand.
This was flying about 50 Ft above me, Swallow tailed Kite
This Is Good…
Try not to let this idea turn into a HiFi system. Photography is similar to HiFi, in being potentially ‘equipment heavy’, with far too much shiny & expensive stuff available, both new & used.
Go carefully. Its your money…
Decision made:
After a lot of research, reading, reviews, visiting shops, and talking to people we placed an order yesterday. We concluded there was no perfect solution ref quality, magnification, and portability/weight.
We decided to order a Bridge Camera, a Nikon Coolpix P950 for less than £600 new. It is light and has serious magnification ( 2000mm equivalent). The big compromise is it’s small sensor, by definition. We thought long and hard about the Sony RX10 IV which has a bigger sensor but less zoom. We handled both.
My wife has a colleague who shoots wildlife and has the Nikon and her results look more than decent for our needs so long as we are aware of it’s limitations. I think the way to think about it is that it is a phone camera quality with a big zoom on it.
Looking forward to seeing what it can do.
Pleased you have made a decision. And… have not allowed Mission Creep to occur…! (as often occurs in HiFi… This ones a bit better, then there is this… etc)
The Nikon may meet your needs for ever. But if not, it will certainly get you started - with a bang…!!
PS. Don’t get hung up on Sensor size… Size, in photography, isnt always everything…
Well done, Try and find a proper guide book in how to use it so you can get the best benefit from it and not just use in Auto.
Such as Nikon Coolpix P950 User Guide: The Ultimate Guide to Mastering the P950 for Beginners, available from Amazon
The book that comes with them are useless.
Or online tutorials
