Ai, Oh Dear!
No doubt we’re all aware of the ai ‘revolution’ going on just now. I thought I’d play around and ask ChatGPT the difference between the Uniti Atoms. Pretty impressive given the speed and how comprehensive it is, and it’s early days of course. Is point 1 a bit misleading perhaps as the amp can drive powered speakers only?
Here’s the full reply.
The main difference between the Naim Uniti Atom Headphone Edition (HE) and the standard Uniti Atom is that the HE model is designed specifically for headphone listening. While both models share many similarities, the HE version has a few key differences that make it stand out:
  1. Dedicated Headphone Amplifier: The Uniti Atom HE has a dedicated Class A/B headphone amplifier that delivers up to 1.5W into 16 Ohms, which is more than enough to drive most high-end headphones. This is in addition to the main amplifier, which is designed to power speakers.
  2. Upgraded Power Supply: The Uniti Atom HE has an upgraded power supply that is designed to deliver clean and stable power to the headphone amplifier, resulting in a more detailed and dynamic sound.
  3. No Speaker Terminals: Unlike the standard Uniti Atom, the HE version does not have any speaker terminals on the back panel. This is because the HE is intended for use with headphones only.
  4. Headphone-Specific Features: The Uniti Atom HE has a few features that are specifically tailored for headphone listening. For example, it has a high-quality 6.3mm headphone jack on the front panel, and it includes a dedicated headphone remote control.
Overall, the Naim Uniti Atom Headphone Edition is a specialized version of the standard Uniti Atom that is designed specifically for headphone listening. It offers the same high-quality sound and features as the standard model, but with a dedicated headphone amplifier and improved power supply that are optimized for headphone performance.
Ai on a roll. All a bit obvious of course but probably good as an introduction.
Q.
Why would I use this as opposed to a full Naim separates system?
Ai.
The Naim Uniti Atom Headphone Edition (HE) is a great choice if you’re primarily interested in headphone listening, and if you want a compact, all-in-one solution that doesn’t take up too much space. Here are some reasons why you might prefer the Uniti Atom HE over a full Naim separates system:
  1. Simplicity: The Uniti Atom HE is an all-in-one solution that includes a high-quality streaming amplifier, a DAC, and a dedicated headphone amplifier. This means you don’t need to worry about purchasing and configuring multiple separate components, which can be time-consuming and complicated.
  2. Space-saving: The Uniti Atom HE is a compact device that takes up very little space. It’s a great choice if you don’t have a lot of room for a full separates system, or if you want to keep your setup simple and unobtrusive.
  3. Cost: While Naim separates systems offer the ultimate in high-end audio performance, they can also be quite expensive. The Uniti Atom HE offers a more affordable alternative that still delivers exceptional sound quality and features.
  4. Portability: The Uniti Atom HE is easy to move around and set up, which makes it a great choice if you want to take your music system with you to different rooms or locations.
That being said, if you’re primarily interested in speaker listening or if you have very high-end speakers that require a lot of power, you may want to consider a full Naim separates system instead. This will give you more flexibility in terms of configuration and power output, and it will allow you to take full advantage of Naim’s high-end audio components.
Well done, Hercole. That’s an interesting experiment. I doubt whether I (or many other forumites) would make purchase decisions based upon AI alone, but AI’s clearly a fun thing to try. :clap:
Maybe it’s fun in the same way that a ‘spot the difference’ puzzle is fun, in this case spotting the difference between things it has got right, and things it has got wrong, which in this example is quite a few.
Archimago recently had a convo with Chat GPT about various audiophile topics. Its pretty good…
Smoke and mirrors can be very convincing. :wink:
Have a listen to this podcast to get a bit more of an in-depth critique of AI:
I’m not asking anyone to agree with it, just to listen to get a better all round perspective.
Spotting all the things it got wrong sounds like fun to me. Maybe I need to get out more.
Yes. At the moment it’s seems a great option if you want answers fast, but aren’t too bothered if they’re correct, ha!
Given it’s based on everything the internet knows at this point in time, is it the beginning of the end or the end of the beginning. :thinking:
Quite.
SI.SO.
Ask it “do expensive cables make a difference?”
And then open up the popcorn and see if it will fight itself :grinning:
Just like the Naim website :wink:
That question was asked and answered about half way through Archimago’s link………….
The answer would not please retailers of expensive cables……
Interesting though not something I’d probably consider a priority for any AI engine.
Perhaps if they used an expensive mains cable on the servers, they’d get a more favourable answer :grinning:
Don’t shoot the messenger…
Does the cost of the speaker cable make a difference in sound quality to audiophiles?
This is a highly debated topic in the audiophile community, and opinions are divided. Some audiophiles believe that the cost of the speaker cable can make a significant difference in sound quality, while others believe that any perceived differences are negligible and that expensive speaker cables are a waste of money.
Proponents of expensive speaker cables argue that they use higher-quality materials and construction techniques, resulting in better transmission of the audio signal and improved sound quality. They may also claim that more expensive cables can reduce interference and distortion, resulting in a more natural and accurate sound.
However, there is little scientific evidence to support these claims. Objective measurements of speaker cables have shown that differences in materials and construction do not necessarily translate to significant differences in sound quality. Additionally, many blind listening tests have failed to demonstrate consistent differences in sound quality between expensive and inexpensive speaker cables.
Ultimately, whether or not the cost of the speaker cable makes a difference in sound quality is a matter of personal opinion. Some audiophiles may hear a difference and believe that it justifies the cost, while others may not hear a difference and prefer to save their money. It is important to keep in mind that the choice of speaker cable should ultimately depend on your personal preferences, budget, and system setup.
Yes, different speaker cables can sound different, and with conventional Naim equipment it’s also important to use minimum cable lengths and cables with appropriate electrical characteristics.
I wouldn’t however say that expensive cables are necessarily better - there will undoubtedly be many expensive ‘boutique’ cables which are just priced high and may sound no better than established standard cables.
Some expensive cables will naturally sound much better than cheaper ones if they are well designehow , but it will ultimately all boil down to synergy with the rest of the system (including rooms and ourselves!) in terms of how much improvement we as individuals will perceive.
Isn’t this just the definition of every internet forum?
