Nova fell off the WiFi for some unknown reason and after multiple resets of it, I can’t get AirPlay setup to complete, errors out with an unexpected error.
Looks like this happened for a period in 2019 according to this post, which is exactly what I’m getting now. Naim app not configuring Mu-so Qb
Thanks, yes. Unit was initially set up under 14.2 and went through that. If you try and do that additional step now of adding the AirPlay speaker the setup fails in the same way as via the app, which I assume is reassuringly consistent!
