I might be being slow but this seems to have disappeared or at least is not where it used to be?
Can someone advise?
Can someone advise?
On a Mu-so or a Qb…?
I’ve just posted on another similar thread – I have a Mu-so with alarm settings and a Qb without…Updates applied earlier today…
SC
Qb2
Same same then….
Seems as though it’s either been dropped on the Qb2 or there’s a bug….
Oh it still thinks there are alarms as it wouldn’t allow me to remove an Internet Radio station from Favourites as it says, correctly, that it is being used in an alarm.
Also, minor point, it doesn’t seem possible to disable some Input Settings from the menu anymore, e.g ‘Analogue’ and ‘Digital’. Again on QB2.
It will ‘allow’ them but they don’t take effect!
I checked that – mine do!
Once toggled off the icon disappears from the source selection in the App….
Hmmm… I mean not a big deal but if we’re reporting bugs…!
Alarm menu present on my Qb2 settings menu unless you mean something different? This is on app version 7.1 (1109500)
I can’t find it on my Qb2.
Is that the App on Android…?
If so, wondering if this is indeed a iOS App issue as @Steeve suggested or if it’s just a random bug as to who is seeing the setting and who is not re the Qb2….?
SC
Almost certainly an iOS app bug I think. I notice it’s still on the menu on my iPad. I haven’t updated the app there but obviously using updated firmware on Muso QB2.
Yes that’s on Android
Same here - MuSo2 - the app let me disable inputs but does not store the settings and they appears still in the app interface.
I’m on Android
I have the Alarm in Settings menu, first menu voice.
MuSo 2 on Android, latest app update
No alarm on any menus on iPad or iPhone 15 - disappointed of Martinborough!
It’s a bug in the Naim app version 7.1 for IOS. It will likely get sorted quickly.
