Hi all. I just discovered that one of my tweeters died silently. A multimeter shows infinte resitance when measuring the broken one (the other one shows zero resistance).
Removing the front plate by loosening the four wood screws is easy (no hylomar or glue). And lucky me that I have bought two replacement tweeters when these were discontinued.
What I’d like to know is what the torque setting will be when refitting the new tweeter to the suspension plate. For the SL2 Richard mentioned 0.8Nm, but does anybody know if this also applies to Allaes?
I feel I should replace both tweeters while at it. Any objections?
Thanks much and love and peace from Germany to you all.
