Alternative sbl mid box filling
Hi Jack.
I’d be pleased to do that when the foam arrives.
ASG have given a delivery date of after 14th April. As I’m replacing the crossovers as well, it will be a full service on the SBL’s so hopefully all will go well. Will post pics in the thread when done.
Regards. Tim.
Yes, of course, that’s fine to post pictures - we could even make an FAQ on it, if suitable.
@Richard.Dane and @TimUK
Thank you both. I’m looking forward to it!
Hi Jack.
Just to temper your expectations, i haven’t done this before either, so I’m just winging it.:rofl:
Will try to give you as much info as possible, & will highlight any problems i encounter.
If it’s ok with Richard, I’ll give details of the company & how much the foam has cost (including vat & delivery).
Ross (the guy i spoke to at ASG) comes across as a really nice guy who’s willing to help anyone with the foam.
Regards. Tim.
I would also be winging it. That’s exactly the perspective I need!
:rofl::rofl::rofl: That’s good to know Jack. :+1:
Regards. Tim.
Are there any benefits to using an appropriate weight / volume of lead-shot to sit at the bottom of the base cabinet, as to further aid vibration damping?
Suggesting a modest 2 kg of lead shot with each SBL, not sure how voluminous that would be but assuming only an inch or so (?)
I can understand why a manufacture wouldn’t find it desirable when sold as a brand new product; extra weight with transit, and then the setting up of an already heavy to move speaker, plus health and safety issues with toxicity.
However with existing SBLs in well set-up home situations this maybe a fairly easy mod to do if gains are there for the taking, as long as the user is content with each SBL weighing in a couple of kilo more, and the cost of buying and the safe handling of the lead shot.
Hi Debs.
I for one wouldn’t recommend doing that, adding anything that will alter the volume of the base box will probably affect the sound reproduction as well.
Reducing the volume of what is just a passive resonance box would reduce the bass frequency of the speaker.
With the SBL’s known for being (shall we say) a bit light in the bass department, you could make things worse by reducing its volume.
Also, getting the loading mass into the bottom box could be tricky, having seen that there is a filter of sorts covering the port.
I would have thought that for adding extra stability to the speakers, the spikes would suffice (especially if placed onto a wooden floor or thick carpet).
I suppose you could try attaching some extra weight (in a bag for instance) to the underside of the speakers. That won’t affect the sound quality, but would (with the extra weight) give you more stability.
At least that will be easy to revert to the original specs, if it doesn’t work out for you.
I hope you find an answer for your problem & let us know how you get on.
Regards. Tim.
I’d echo what Tim says above. I had some Acoustic Energy speakers years ago, they had a dedicated chamber in the bottom of the cabinet for lead shot. I wouldn’t want to put it within the acoustic loading chamber, as that would be defeating the original design.
Neil.
Update on SBL foam replacement.
Sorry for the delay in getting this done, had a few other things to deal with.
Hopefully the pics show up ok.
The foam arrived & looks perfect for the job (dimensions & material wise), so that’s good.
I thought i should mention that i cleaned the mid-drive unit whilst it was still attached to the main body of the speaker cabinet.
In hindsight, i should have removed the mid-drive cabinet before cleaning the drive unit.
This would have allowed me to rest the speaker drive unit face down on a flat surface without potentially putting strain on the wires to it. Oh well, live & learn.:thinking:
Next four pics show how the original foam fits in the mid drive cabinet.
Looks easy enough to replicate with the new foam.
This shows the original foam in its degraded state. Basically it’s crumbling to nothing when touched, (so it definitely needs replacing).
Surprise number 1.
I need 2 sheets of the foam per speaker. :frowning: Correction……3 sheets of the foam per speaker. The third is hidden behind the second one, but in the same position as the other 2. :confounded_face:
This is turning out to be an expensive repair as the first order of 2 pieces of foam came to £106.73 inc vat & delivery.
Whoever said listening to music was easy & cheap wants their head examined.
That’s just put the full repair back a while. At least i can do one of the pair.:worried:
Erm……Not so fast smarty pants…….Just re-ordered the next 2 pairs… so will be a few weeks more. :frowning:
Before removing the old foam, i decided to remove the old gasket seal from the drive unit. BE WARNED!!! this (if you need to do it) is a messy & smelly process. Be careful of the drive unit as this chemical COULD, (not known for sure) damage it if it got on the cone or coils.
Saying that, it is an easy process using the Boots Acetone Free nail varnish remover & plenty of clean cotton buds. I didn’t use isopropanol because i didn’t have any, so not sure if that would work too.
Just dip the bud in the solution ( neat nail varnish remover) & apply to a small area of the old gasket to be removed. Leave it to soak in for a few seconds, then rubbing the cotton bud over the area, it will lift the gasket seal ( old Hylomar Gasket) of the drive unit surround.
Take your time with this, & don’t rush it. You’ll get old gasket & solution on your fingers & hands, so, if sensitive to the chemicals, wear nitrile gloves.
I didn’t…& my hands stink of acetone (even though that’s not in the solution) :face_with_spiral_eyes:
As mentioned before, i didn’t remove the mid-drive cabinet from the bass box. That’s my next step. This can be easy or hard, depending on how the two were fixed together before. If correct procedures had been followed ie with an application of soap on the foam gasket surround before the silicone sealant was applied…. then the two cabinets should separate relatively easily, without damaging the foam gasket.
This was the case for me, as i had previously renewed the silicone gasket seal when i’d purchased my SBL’s second hand.
This has left my foam gasket intact & with minor damage to it’s surface. Because of this (lucky break) i shall not be removing & replacing the foam gasket. :nerd_face:
See pics below showing old silicone sealant remaining & the condition of the foam gasket.
Removal of the remaining sealant is easy as it just peels off relatively cleanly.
Next job is to inspect (& if necessary) replace the aluminium plates that the cabinet sits on. My ones were made up by me from an ally drinks can, cut into shape & stapled in place. They look rough ( but they worked fine, following the dimension found on the forum elsewhere. Now i have the correct pieces from Amazon, i shall replace them.
Surprise No. 2.
OUCH!!! i’d forgotten how damaged the cabinet was underneath the ally plates.
Time for some filler….
Not sure what to use here because most fillers set too hard & the difference in density might affect the sound of the speakers.
They should be firm, but compliant to mimic the wood of the cabinet.
Any ideas would be gratefully accepted.
For now. this part goes on hold as i don’t want to put the new ally plates on something that is too hard for the spikes to either sit on, or potentially penetrate.
While that’s on hold, i can (at least) replace the internal foam.
This will be messy as the foam has degraded so much .
No need for pics for this as the previous ones cover where & how it fits inside the cabinet. I will just be mindful of the foam particles & where they go during this procedure. Dust covers & a vacuum cleaner on low power should do the job.
That’s all for now. I hope this helps anyone having to do the same to their SBL’s.
If anyone has any ideas what i can use as a filler for the cabinet holes i would be very grateful for your suggestions posted here.
Thanks for now. Tim.
Good work Tim . I used P38 car body filler to fill in the area under the Ali pads. Worked well!
Hi Jack, just to let you know, i’ve put the first few pics up on how to replace the internal foam in the SBL’s.
Hope it helps.Tim.
Thanks for that Cohen. I will look into that. :nerd_face:
Kind regards. Tim.
