Amp Issue
I have a DR250 Power Amp. A few weeks ago I noticed that it was running much hotter than normal even though I just had the volume on very low. It is now only playing through one speaker. Has something burnt out and if so anyone have an idea of how expensive this will be to repair? I assume I need to take it to a local dealer and they will send it back to Naim.
Don’t know why this has happened - it hasn’t been heavily used!!
Check whether there are any shorts with the speaker cabling or with the connectors or speaker terminals.
Out of interest, what speaker cabling are you using?
If it requires repair then this should be arranged through a Naim dealer who can also get you a repair estimate.
