Just a quick question, which would be better for a Nait5 a Nap 100 or the Nap150x?
I think the consensus back in the day was a FC2. At least, that’s what I had on my Nait 5 and was very pleased with the combo.
I would go 150x, I’d also sell the Nait and buy the matching Nac 122x.
The 122x / 150x was my first full size Naim separates amp and still remains one I have very fond memories of.
I have a FC 2x. I am looking for the next small upgrade so looking for a power amp to add to the system.
The 150x is a really nice power amp so I’d go for that. Then swap the Nait 5 for a 122x as suggested above. I had a 122x/fc2x/150x for three years and it was terrific.
The Nait 5 would be a straight swap financially for a 122x and as you already have a flat cap it makes great sense.
Your only outlay would be around the £300 mark.
Ah. So why didn’t you say?!
The guy asked a simple question. You ignored it!
Just as I’m about to save and go for 202/200
NAP 150X would be my choice
Thanks for the reply’s, 150x it is then👍
