Another update and still the search function (magnifying glass) of upnp still not working. Anyone else having problems?
Synology Nas
Minimserver
Synology Nas
Minimserver
Correct @redged , not fixed in this update.
As I said last time HQ have logged it and are working on it.
They say hopefully for the next release which won’t be too far away.
Cheers for the update Chris
The Tidal search seems to be broken too. It looks as though it’s trying to do a lookup as you type each character into the search field instead of waiting until you finish typing. While it’s performing the lookup, any other characters you type are lost. It used to do this several releases ago (a year or so) but they fixed it. Now it’s back again.
