Annual Solar generation down 10% - Weather change?
Mine is very similar to that. I’ve had it plugged in since May to give me an idea of what’s happening. SP will certainly reject any claims made on the basis of measurements from such a device, but it’s additional evidence along with inverter shutdowns, buzzing transformers etc.
Just a thought, can you try it in a couple of neighbours house. In my street, there are three runs from the substation, and split such that my house will be on the same run as 3 houses further down the road, so your immediate neighbour (if friendly) will be on a different run from the substation, and might be useful to see how theirs vary.
Another thought is to raise a concern on possible damage on appliances running on voltages outside their spec. If they knew the cost of your HiFi, that may help your case
My two nearest neighbours are close friends, so I’ve had them use my socket tester to check their Voltage. They both read high, so yes, that is being added to my list of evidence to try to force SP to do something. We are the last 3 houses on the end of the cable from the substation about half a mile away, so if anything you’d normally expect our Voltage to be a little lower than others.
Assuming you don’t have a power cut and your inverter is running in island or isolation mode, then yes what the grid is doing is relevant when running ‘from’ batteries.
Your batteries via the inverter augment the connectivity from the grid. What happens is the inverter detects how much power your house demand is using (via the CT clamp ) and the inverter closely matches that by adding power into progressing the phase minutely so as to match power being used. Net result you don’t draw additional power from the grid. At a very low level it’s not perfect and has a slight lag, so you see little spikes of low level draw or export to the grid but is almost irrelevant.
But the voltage phase (and current phase) , and phase frequency as well as the grid voltage all have to be monitored closely by the inverter to do this. So your inverter is totally in sync with the grid and follows the status of the grid conditions when you are using your batteries to draw no additional power from the grid.
Your phase across your substation locale can vary by about 1 to 5 degrees between houses and businesses depending on loading (and generation)
Thanks Simon, that makes perfect sense. I tend to think that in this case, so long as everything works, I won’t worry. I’m a real worrypants and don’t want anything else. I was just intrigued.
It might be worth remembering if you are not familiar with AC that voltages for the mains mean different things depending on context .. and you can’t always mix and match.
When one says the mains is 240 Volts - it is a short hand for 240 Volts(RMS) for one of the cycle sides (half a cycle) and so it’s actually 340 V relative to ground. [240 * SQRT(2) ]
However the mains is sinusoidal with an average of 0volts over a full cycle = so the actual peak to peak volts is actually around 680 V (Pk to Pk) from 240 V(RMS) mains.
The reason we use 240 V (RMS) as the measure for mains is that it is roughly equivalent to the equivalent heating power from 240 VDC but it’s not the actual volts.
Soo an AC multimeter for reading the mains of 240 V(RMS) usually needs to be rated for at least 680 V (depending on design). if you were measuring the mains on an oscilloscope you would see a range of 680 Volts over a cycle.
In other words 240 V(RMS) does not equal 240 actual volts.
We’ve been taking part in the Octopus savings sessions for ages now, even though we don’t really save anything because we export when they are on. Taking part has given us 7 hours of free power on a Sunday. During the summer we’ve not been able to use them because the solar keeps the batteries full and exports. But the forecast for today was foggy, and because it’s quite cold the heat pump is running down the battery faster than the solar can fill it up. So we’ve scheduled our first ever free power for two hours this morning, from 9 until 11. We will do some washing, tumble dry the towels and top up the batteries. Then by 11 the batteries will be full and we can export, so long as the sun is out by then.
What’s odd is that Octopus say they make these sessions available when there is lots of clean power around, yet the agile export rate doesn’t drop below 17p all day today. I imagine it’s more of a customer loyalty thing than anything based on costs of power, and the 16kWh fair use limit puts a cap on things. Still, it’s good to try it out and to see how long the credit takes to come through.
I’ve taken part in quite a few Savings Sessions but I’ve never earned any free energy, only a few Octopoints. How can I get some?
You just have to do enough savings sessions and you get the tokens for free hours. Two tokens for an hour usually.
Thanks, I’ve not done as many as you so I guess that’s the reason.
Prior to Capture AI were you using the FoxCloud app? I note that has a preset mode scheduler for Octopus Agile, which I assume gives control to Octopus(?).
We’re currently locked to British Gas, which is highly favourable for our gas heating and their electricity feed-in tariff isn’t bad, but we’re starting to assess options for when our fixed term is up in February. Prompted by your post I had a look at the Fox website, where the Capture AI info is rather sparse, but it appears that once in use it is possible to turn it on and off so it seems no disadvantage to having it.
Interestingly I see it claims to predict solar generation - but that surely is of doubtful use as different weather forecasters don’t often agree on when it will be sunny or cloudy here, and even when they do it is not uncommon for them to be wrong!
I’ve even turned the oven on at 200° to roast the lovely pumpkin that arrived in our veggie box. Rarely am I roasting pumpkins at 9.30 in the morning. I’m also charging up the car, might as well. Just remember to stop it at 11.
Once you’ve had solar for a while you can look out of the window and know roughly what the day’s generation will be. Who needs AI when you have senses. Like we know the washing won’t dry if the table on the patio is wet.
Indeed, though personally I like to know the weather in advance, preferably at least the day before and particularly whether rain is likely, to plan things rather than wait for the moment.
I think the idea of the predictive app. is to decide in advance whether to charge batteries overnight. Whether AI is of use for that I don’t know - presumably it can monitor weather forecasts.
Our batteries ran out for the first time yesterday after an awful week for solar, and as our BG tariff offers cheap electricity on a Sunday (slighly lower per unit than the export rate) I have set it to charge during the cheap period today. An easy process but manual and needs doing by the day so I have to remember to turn off after. It appears possible that the AI add-on might automate the process, though it is so simple as to not need it as long as I set an alarm to cancel (maybe different with some other tariffs).
Sounds cool AI, but I’m sure it steals the data elsewhere and then presents it to you as its own product.
AI is the biggest robbery in mankind.
It’s simple for us, we fully charge the battery every night, come what may, during the six cheap hours from 11.30 to 6.30. Then any solar runs the house as first priority, then charges the battery, then exports anything spare. This is all automated and just works. At the moment we do a forced discharge from 4 to 7pm, with the system set to stop discharging if the battery depletes to 40%. The 40% is nearly always enough to get us to 11.30pm, when we again draw grid power. If the weather is freezing we just stop exporting or increase the 40% to keep more in reserve. At the moment we are running entirely from solar, and exporting a bit as well, which is good for November.
With BG the only cheaper rate is Sundays 11:00-16:00, so on other days it is cheaper not ti charge from the grid - as long as solar provides enough. This is the first week solar hasn’t since it was installed back in July (Thursday was worst day yet, only 1.1kWh solar, and batteries ran out mid Friday when solar wasn’t much better. 4x as much solar already today, and with batteries charging from the cheap supply now they’ll be full and so hopefully we shouldn’t have to buy electricity again till next week. (As long as at least 2 or 3 days with moderate brightness if negligible the other days. But darker shorter days are coming!
I’m guessing we may change to Octopus in February, and will probably consider an electric car some time - maybe another battery would be beneficial too, but early days yet. I am far from convinced that heat pump is the way to go at the moment - a few years time maybe.
Without wishing to go too far off topic, what makes you wary of a heat pump? If you have an old and draughty house I can understand it, but if it’s well insulated there shouldn’t be an issue. With our EV and solar, and the pump, we haven’t spent a penny on power for nearly two years, and that includes charging the car. The house is much more toasty than it ever was with gas heating.
Perhaps you can describe your system and the installation? Generally having a greater understanding helps allay fears and scepticism.
I’m happy to try to address those fears, but I’d rather know what they are first. Otherwise it would just be wasting my time and boring others.
