FIT T&C’s - This is from my EON-Next FIT agreement:
11. Changes to Your System
11.1 You must let Us know in writing if You make any modifications or changes to Your System (including any extensions, installation of any Storage Device, changes to meters, including if a smart meter has been installed and/or the installation of an Export Meter) as this may affect its eligibility and capacity calculations which, in turn, may affect Your Tariff Code, Generation Tariff and Export Tariff. Let us know immediately after any modifications or changes have been made.
11.2 If you don’t tell Us and we then discover or are made aware that modifications have been made then We’ll notify Ofgem who will take appropriate action which may include changing Your Tariff Code, changing the amount of any FIT payments payable and/or recovering from You any amount of a FIT Payments that should not have been paid. As such We reserve the right to suspend, withhold or recoup any FIT Payments in accordance with Ofgem’s instructions.
11.3 If the change to Your System impacts Your T ariff Code and/or Generation T ariff unit rate, Ofgem will notify Us of any change and We will in turn update You of the change to be made and may send You a revised FIT Plan by email or post. Any such change will take effect from the point at which the Central FIT Register is updated by Ofgem.
11.4 Any extensions commissioned on or after the New Rules Date that increase Your System’s capacity will not be eligible to receive FIT Payments.
11.5 Any Meter Readings received by Us from a System that has had an ineligible extension (as described at clause 11.4 above) will be prorata if the System and ineligible extension share a Generation Meter and/or an Export Meter.
11.6 We shall have the right to request any more details for the Meter Reading received and referred to in clause 11.5 above if We or Ofgem believe or consider the said Meter Reading does not fall within the “expected tolerances” for electricity generated and/or exported by Your System.
11.7 If You have a Storage Device connected to or installed for Your System You must notify Us at the start of this Agreement and provide Us with a copy of the schematic diagram of the Storage Device which will need to show the installation, the Storage Device and the metering arrangements. If You don’t have this, You will need to contact Your Storage Device installer to obtain a copy.
11.8 If You have a Storage Device installed at any point after the start of this Agreement, You must notify Us as soon as possible and provide the information referred to at clause 11.7. If this information is not provided as requested, We reserve the right to notify Ofgem who shall take the appropriate action it deems necessary.
11.9 Where there is a Storage Device present and You do not have an Export Meter, You shall only be entitled to receive FIT Payments for electricity generated by Your System and deemed exported electricity if Your Generation Meter is capable of isolating the amount of electricity generated by Your System. If You have an Export Meter, You will only be entitled to receive FIT Payments for electricity exported to the local electricity network if Your Export Meter is capable of isolating the amount of electricity exported by Your System.
