On my Uniti2 I am using 2 jack plugs for my rega Asia mc phono stage,but wonder if it would make any difference using the dedicated 5 pin phono socket,don’t want to buy a new cable if it’s not necessary.
The dedicated DIN socket for phono on the Uniti2 is a powered 240 degree DIN, for use with a Stageline, Prefix or Superline Phono stage (provides 24v DC power and takes in the signal), so unsuitable as an input for your Rega phono stage. Stick with the RCA Phono input.
Thank you very much,saved me buying something I don’t need.
